The Lexus NX is a luxury compact crossover sold by Lexus, the luxury division of Toyota. It was introduced in late 2014 as an all-new, entry-level crossover model in Lexus' lineup, slotted below the mid-size RX crossover. The name NX stands for Nimble Crossover.
2 Questions View all
NX200t Model 2015, Error Code B15D0 & B1585
Hi! my Lexus nx200t year model 2015 Audio system is working well, No short Fuses also AMP is working but no sound even volume control is not gauging nor radio station changing the channel. where i diagnose the error code B15D0 & B1585.
if any one can help me to fix by own it would be great or at least locate me the MOST connector of the given model.
thanks in advanced!
Add a comment
1 Answer
Chosen Solution
Greetings,
The first error code is a communication error in the system. The second error code is a USB device malfunction.
I found some information on the communication error here. I am unfamiliar with this Lexus system as I stopped working on them quite a few years back
https://carfixlib.com/b15d0-most-communi...
The second code could simply just mean you have a bad USB or unsupported USB plugged into the system.
I hope this helps you along a little bit.
Cheers
Monte!!
Add a comment
Add your answer
Syedma will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 18
Past 30 Days: 48
All Time: 231
