Launched in the first half of 2022, the Asus TUF Gaming A15 FA506IV is based on an AMD RYZEN 4000 CPU, NVIDIA RTX or GTX GPU, and a 15.6 inch 1080p display.
14 Questions View all
Power button not working. Disassembled before it's inaccessible.
ASUS TUF A15 Gaming Laptop (Model FA507) As the title says, the power button has stopped working. The charging light comes on fine when plugged in. I'm 99% certain the power button is the issue, as it was becoming increasingly finicky over the past few months. I would have to press repeatedly in slightly different ways until I hit the "sweet spot" and it turned on. Or sometimes it wouldn't work, until I put it away in my backpack and tried again later. This leads me to believe there is an issue with the connection between the power button and the rest of the board. Now that that's out of the way...
I'm extremely broke, and am in my final year of uni to try to escape poverty. I got a quote from a local repair shop for $700 and three weeks of repair, which I definitely cannot afford (in both time and money). So I figured I might as well and try to apply some of that electrical engineering knowledge I've been gaining at school. I'm currently taking a PCB design class, and am starting to become familiar with working hands-on. But after having fully disassembled the laptop, I found out the hard way that there's a metal plate covering the back side of the palm panel that cannot be removed. I should have watched a tear down video first. I'm incredibly dumb, I'm sorry 😔
I was thinking about devising a work around if I can identify where the signal from the power button interfaces with the mother board. If I can find that, I might be able to engineer a DIY method of shorting that connection (thus simulating the power button). I've identified three ribbon cables coming out of the palm panel, indicated by the red arrows. The teal arrow points to the cable for the touch pad, and the yellow arrow points to the WLAN chip. The power button is located at the top left in the first photo. I suspect it might be the topmost cable (5th and 6th photo) due to it's closest proximity to the power button. The leftmost cable (2nd and 4th photo) is yellow and is marked with the text VCC and RBG. While it seems promising, I think it might just be for the rgb lighting of the keyboard. The battery connects to the wire at the bottom of the 7th photo. Can anyone help me identify which trace is associated with the power button? I have a multimeter, and can provide additional photos as needed. Thank you in advance!
I cross posted this on Reddit in hopes of increasing exposure. I hope that's okay!
Score 3
1 Comment
Olá @ilayschipz
Uma possibilidade para encontrar os pinos correspondentes ao circuito de ligação do botão Power é verificar a (as) trilha (s) mais grossas (espessa) que aparece no cabo flat do teclado (terceira foto). Essas trilhas costumam ser mais espessas porquê o botão Power precisa de uma carga maior de energia do que apenas o toque de uma letra. Observe isso e me dê o retorno, especifocando como procedeu caso tenha funcionado. As instruções do @jayeff
by
Add a comment
Most Helpful Answer
Hi @ilayschipz
With the laptop assembled so that it can start, try connecting a momentary¹ earth to pin 5 of the keyboard cable connector socket on the motherboard to simulate pressing the power button and check if the laptop starts.
Unfortunately looking at images of the board that you posted I'm not 100% sure which end you need to count the pins from.
The 15 pin socket to the right of the 36 pin keyboard socket is marked i.e. a dot shown at pin 1 (left side in image) and the #15 shown at the other end but the keyboard socket only shows a dot next to the "KB" board designation and nothing at the other end, so hopefully it counts in the same direction.
Be aware that there is +5V DC on pin 1 so be careful that you don't apply a direct earth to it as you may either blow a fuse on the board or damage some other component.
¹ momentary = length of time to simulate pressing the Power button to turn on the laptop but not long enough to simulate a force shutdown i.e. < 4 seconds
Score 3
1 Comment:
Alguém poderia fornecer a folha com o circuito da placa mãe?
by
Add a comment
Com a folha dos circuitos da placa mãe é possível saber exatamente qual e onde se localiza os pinos de ligação da trilha do botão Power
Atualizar (05/30/24)
Olá @ilayschipz
Uma possibilidade para encontrar os pinos correspondentes ao circuito de ligação do botão Power é verificar a (as) trilha (s) mais grossas (espessa) que aparece no cabo flat do teclado (terceira foto). Essas trilhas costumam ser mais espessas (conforme imagem anexada) porquê o botão Power precisa de uma carga maior de energia do que apenas o toque de uma letra. Observe isso e me dê o retorno, especificando como procedeu caso tenha funcionado, estou com um problema similar, porém não estou conseguindo fazer o teste. As instruções do @jayeff podem te ajudar a testar as trilhas que indiquei.
Add a comment
I’ve encountered an issue where the two layers of the keyboard’s power-on button are constantly short-circuiting, sending both shutdown and power-on signals to the EC. I’m wondering if there’s any way to deactivate this behavior and instead solder a button directly to the power-on pin on the motherboard. Unfortunately, I can’t seem to locate the specific pin or find any schematics to guide me in this process. Would the best solution be to simply replace the keyboard?
I also tried soldering a button directly to the GND and the 5th EC pin, but it didn’t work due to interference from the power-on keyboard layer
I’m asking this because I’m 100% confident that by soldering a button to the EC, it will take the keyboard logic into account
Add a comment
Add your answer
Toasted Rice will be eternally grateful.
Past 24 Hours: 14
Past 7 Days: 107
Past 30 Days: 481
All Time: 4,195
