The 7th-generation Surface Pro, released in October 2019. Available in platinum and black. Model number: 1866.
28 Questions View all
My screen won't turn on after I replaced it
The light showing the battery is connected is lit up, and the backlights on the display are on too, but the most I get is a faint flash of color before it turns off again. Any possible problems/solutions
Add a comment
1 Answer
Did you plug the display into the connector of the motherboard correctly? If not, that that may have caused this issue. Make sure to reinstall the display connector, and it should work correctly.
Add a comment
Add your answer
Russell Hoskins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 11
