Laptop isn't coming on.
It was charging fine(it's not the charger, tested it on another ThinkPad and it works fine) and it died while it was charging my phone(my laptop has died on my phone before and it's been fine, this was the second time I'm charging my phone with my laptop) when i plugged it in it didn't blink the red lights to show charging and it didn't come on even when I took out the battery
Add a comment
1 Answer
Hi @ebubechukwuo449
There may be a problem with the power connector port (aka DC-In jack) in the laptop.
Sometimes the inner +ve conductor of the jack can fail intermittently causing no power to be received by the motherboard from the charger.
Here’s the hardware maintenance manual for the laptop Go to p.86 to view the procedure to remove /replace the DC-in sub card
Follow the procedure and just disconnect the power port cable plug from the card and then connect the charger to the power port. Use a voltmeter to measure the voltage on the red and black wires of the plug. If there is 19.5V DC when measured at the port's cable plug, then gently move the charger's plug up and down and side to side (not in and out) inside the power port to see if the voltage remains constant or comes and goes.
If it comes and goes or if there's no voltage at all, the jack is faulty and will have to be replaced as it cannot be repaired.
Search online for 04W6951 to find suppliers that suit you best.
Add a comment
Add your answer
Ebubechukwu Onwukwe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 13
All Time: 64
