Why won't my laptop turn on after pressing the power button
After pressing the power button, it won't turn on and the charging indicator turns on when the laptop is plugged to a power source
Here is one possible route to follow:
HP Laptop BIOS Recovery Win and B or V Key
Another:
Shut down. Disconnect charger, open case and disconnect the battery. Press and hold power button for 30 seconds.
Now some just reconnect the battery and try the power button. I prefer to first plug in the charger to see if it works. If yes then you know the charger works and the battery may be defective causing a short. Then disconnect the charger and reconnect the battery. If it works the BIOS was probably corrupted somewhere. If not replace your battery.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 9
All Time: 9
