1 Answer 0 Score |
Why did applications stop opening on my Acer Spin 5? |
1 Answer 2 Score |
Replaced Battery - Battery not working anymore |
1 Answer 1 Score |
Battery not quite fitting …. |
1 Answer 0 Score |
How to change battery |
Background and Identification
The Acer Spin 5 is a mid-range Windows 10 laptop with four different screen orientations that allow the laptop to double as a tablet or movie streaming screen by rotating the display. The Acer Active Stylus is an AAA-battery powered pen for sketching and writing, which can be purchased separately. The Acer Spin 5 was sold around the world with various models and configurations, depending on the region.
The Acer Spin 5 includes an Intel Core i5 processor and an Intel UHD Graphics 620 graphics controller. It includes a standard memory of 8 GB DDR4 RAM. The laptop includes 256 GB of internal storage. The Spin 5 contains a 4670 mAh Lithium-ion three-cell battery. A review of the Acer Spin 5 from Tech Radar found that the laptop has a battery life of approximately 7 hours, depending on usage, which is much lower than Acer’s advertised 13-hour battery life.
The Acer Spin 5 includes a magnesium-aluminum alloy body. It includes an HDMI, USB-C, and two USB 3.0 ports on the left side and an SD card reader, headphone jack, and a USB 2.0 port on the right. A volume rocker and a power button are located on the right side of the computer’s housing. A large trackpad is centered with the keyboard, so it is slightly off-center with the laptop’s housing as a whole. A fingerprint reader is located in the top-left corner of the computer’s trackpad. The Spin 5’s speakers are placed below the display between the two hinges.
Technical Specifications
Operating System: Windows 10 Home
Processor:
- Processor Manufacturer: Intel®
- Processor Type: Core™ i5
- Processor Model: i5-8250U
- Processor Speed: 1.60 GHz
- Processor Core: Quad-core (4 Core™)
Display and Graphics:
- Graphics Controller Manufacturer: Intel®
- Graphics Controller Model: UHD Graphics 620
- Graphics Memory Technology: DDR4 SDRAM
- Graphics Memory Accessibility: Shared
- Screen Size: 33.8 cm (13.3")
- Display Screen Type: LCD
- Display Screen Technology: In-plane Switching (IPS) Technology
- Screen Mode: Full HD
- Backlight Technology: LED
- Touchscreen: Yes
- Multi-touch Screen: Yes
- Screen Resolution: 1920 x 1080
Memory:
- Standard Memory: 8 GB
- Memory Technology: DDR4 SDRAM
- Memory Card Reader: Yes
- Memory Card Supported: SD, SDXC
Storage:
- Total Solid State Drive Capacity: 256 GB
- Solid State Drive Interface: Serial ATA/600
- Optical Drive Type: No
Network and Communication:
- Wireless LAN Standard: IEEE 802.11ac
Built-in Devices:
- Microphone: Yes
- Finger Print Reader: Yes
- Number of Speakers: 2
- Sound Mode: Stereo
Interfaces/Ports:
- HDMI: Yes
- Number of USB 2.0 Ports: 1
- Number of USB 3.0 Ports: 2
- Number of USB 3.1 Gen 1 Ports: 1
- Total Number of USB Ports: 4
- USB Type-C: Yes
- USB Type-C Details:
- USB 3.1 Gen 1 (up to 5 Gbps)
- DisplayPort over USB-C
- USB charging 5 V; 3 A
- DC-in port 20 V; 45 W
Software:
- Operating System: Windows 10 Home
- Operating System Architecture: 64-bit
Input Devices:
- Pointing Device Type:
- Stylus
- TouchPad
- Keyboard: Yes
- Keyboard Backlight: Yes
Battery Information:
- Number of Cells: 3-cell
- Battery Chemistry: Lithium Polymer (Li-Polymer)
- Battery Capacity: 4670 mAh
Power Description:
- Maximum Power Supply Wattage: 45 W
Physical Characteristics:
- Height: 15.90 mm
- Height (Front): 15.90 mm
- Height (Rear): 15.90 mm
- Width: 324.4 mm
- Depth: 226 mm
- Weight (Approximate): 1.60 kg
- Colour: Steel Grey
