Battery
1 Answer 0 Score |
Motherboard/Logic Board replacement |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Acer Spin 7 SP714-51 is a 2-in-1 convertible laptop released by Acer in 2016. This laptop is an ultrathin and portable device for business and personal use, retailing when new for about $950. The Spin 7's construction is durable and the interior boasts an impressive touchpad and keyboard with a premium feel.
Identification
The model number can be located on the underside of the laptop on a black horizontal label. There are submodels of this laptop with different hardware configurations; to find your exact hardware configuration, note the last four digits of your model number: SP714-51-XXXX. Searching up this model number will let you know the exact hardware inside your configuration.
Technical Specifications
- Screen: 1920 x 1080p, 14" Touchscreen
- GPU: Intel HD Graphics 615 (Integrated)
- CPU:
- MO24, M4YD - Intel Kaby Lake Core i7-7Y75 CPU
- MO9D – Intel Kaby Lake i5-7Y54
- Ports: 2 x USB 3.1, mic/headphone
- Operating System: Windows 10 Home
- Storage: 256GB mSATA SSD
- Memory: 8GB RAM
- Battery Life: 8 Hours
- Weight: 1.2Kg (2.64 lbs)
- Size: 324 mm or 12.78” (w) x 229 mm or 9.04” (d) x 10.9 mm or 0.43” (h)
