Siri Remote Battery/Charging Port Combo
2 Answers 1 Score |
Replacement Battery for Apple TV Remote A2540 |
1 Answer 0 Score |
Does the new 2021 Apple TV Remote have a secret U1 chip? |
1 Answer 0 Score |
Broken clips on the bottom panel |
2 Answers 1 Score |
I noticed the new remote looks to have 2 torq screws at the bottom |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If your Apple TV 4K is not functioning properly, check out the troubleshooting page.
Background and Identification
The exterior dimensions of both the Apple TV 4K unit and this 2021 version are identical down to the weight. The Apple TV 4K (2021) is available in either 32 or 64 GB versions. The differences to the previous 4K model is the use of HDMI 2.1 and Color Balance abilities in combination with an iPhone.
Also the Siri Remote has been redesigned to a one-piece aluminum control with a power button, ring touch enabled clickpad.
Technical Specifications
Hardware
- CPU: 64-bit A12 Bionic processor
- RAM: 3 GB
- Storage: 32 or 64 GB NAND Flash memory
Connectivity
- Wireless
- 802.11ax Wi‑Fi 6 with MIMO; simultaneous dual band (2.4GHz and 5GHz)
- Bluetooth 5.0 wireless technology
- IR receiver
- Ports
- HDMI 2.1
- Gigabit ethernet
- Built‑in power supply
Siri Remote Specs
- Bluetooth 5.0
- IR transmitter
- Lightning connector for charging
- Rechargeable battery
Dimensions
- Apple TV:
- Height: 1.4 inches (35 mm)
- Width: 3.9 inches (98 mm)
- Depth: 3.9 inches (98 mm)
- Mass: 15 ounces (425 g)
- Siri Remote:
- Height: 5.4 inches (136 mm)
- Width: 1.4 inches (35 mm)
- Depth: 0.36 inch (9.25 mm)
- Mass: 2.2 ounces (63 g)
Additional Information
- Apple: Official Page
