1 Answer 0 Score |
I want to have ram increased |
1 Answer 0 Score |
Which HDD or SSD are compatible with this device? |
1 Answer 0 Score |
Touchpad won’t work |
1 Answer 1 Score |
The front of the power adapter cable is broken, it does not work |
Background and Identification
Released on June 6th, 2016, the Asus E402M notebook is a 14-inch budget laptop in the Eeebook (entry-level notebook) series produced by Asus. With an LED backlit display and a screen resolution of 1366 x 768 pixels, the E402M is designed for everyday tasks. Moreover, the E402M is powered by a 64-bit Intel Celeron N2840 processor that clocks in at 2.16 GHz (max up to 2.58 GHz). It also comes with DDR3, 2 GB of RAM and 32GB of EMMC internal storage, of which on 16-19 is accessible to the user.
In terms of design, the E402M has a premium feel compared to its selling price. The body of the notebooks has a metallic finish with a single tone color throughout the entire body. Then, the trackpad is a single piece which includes both left and right clicks inside. Asus’ branding can be found on the back of the display.
Technical Specifications
- Operating System: Windows 10 Home, 64-bit
- CPU: Intel Celeron N2840/ 2.16 Ghz
- Max Turbo Speed: 2.58 GHz
- Number of Cores: Dual-Core
- Cache: 1 MB
- RAM: 2 GB
- Memory: DDR3 SDRAM
- Display: LED Backlight, Widescreen Display, 34.6 cm diagonal
- Screen Resolution: 1366 x 768 (HD)
- Graphics Processor: Intel HD Graphics
- Hard Drive: SSD, 32 GB
- Card Reader: 3 in 1 card reader, SD Memory Card, SDHC Memory Card, SDXC Memory Card
- Battery: 32 Wh, 2-cell, lithium ion
- AC Adapter:
- Input: AC 120/230 V 950/60 Hz)
- Output: 33 Watt. 19 V, 1.75 A
- Connectivity:
- Headphone/microphone combo jack
- USB 3.0
- VGA
- USB 2.0
- HDMI
- LAN
- Networking: 802.11b/g/n, Bluetooth 4.0, Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEE 802.11n
- Color: dark blue
- Dimensions & Weight:
- Width: 13.3 in
- Depth: 9.3 in
- Height: .9 in
- Weight: 3.64 lbs
