Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background
The Barreto 1620B Tiller is a hydraulic tiller designed for landscape contractors and nurseries, featuring a Briggs 16 HP Vanguard V-Twin Engine and a 51 cm working width. This tiller is suitable for demanding soil conditions, such as unworked ground, and includes counter-rotating tines to handle sod and compacted soil. For maintenance, marked grease points are present, and free-wheeling hubs enable transport without starting the engine. The hydraulic system contains a bypass, height-adjustable operating lever, and straightforward controls. Locate the model number on the product or in the owner's manual.
Technical Specifications
- Engine: Briggs 16 HP Vanguard V-Twin
- Working Width: 51 cm
- Weight: 252 kg
- Dimensions: 196 x 69 x 112 cm
- Type: Barreto Tillers 1620
- Speed: 1.55 km/h (forward and backward)
- Fuel: Gasoline
- Fuel Capacity: 1.75 U.S. gallons (6.6 liters)
- Engine Oil Capacity: 1.38 quarts (1.36 liters)
- Reservoir Capacity: 14 U.S. gallons (52.99 liters)
- Ground Drive, Forward: 0-80 rpm
- Tine Speed: 260 rpm
Repair Technician Information
- The hydraulic oil filter should be changed after the first 50 hours of use, and then every 200 hours after that. It would be good to have one of the 03951 hydraulic oil filters on hand.
