Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background
The Bio-Rad iCycler IQ is a thermal cycler used in molecular biology research for the detection and analysis of nucleic acid sequences. It is a part of Bio-Rad's family of real-time PCR devices, which are designed to provide high sensitivity and specificity in DNA amplification. The iCycler IQ features a high-resolution optical system that is capable of detecting multiple fluorophores simultaneously, allowing for the detection of multiple targets in a single reaction.
One of the key features of the Bio-Rad iCycler IQ is its ability to perform real-time PCR, which allows for the detection and quantification of PCR products as they are being amplified. This feature is made possible by the device's advanced optics, which enable the detection of fluorescent signals in real time. The iCycler IQ can also perform endpoint PCR, which involves detecting PCR products after amplification has been completed.
The Bio-Rad iCycler IQ is a compact and versatile device that can accommodate a variety of PCR reaction formats, including tubes, strips, and plates. It has a large, intuitive touchscreen interface and comes with powerful software for device control, data analysis, and experiment design. The price of the iCycler IQ varies depending on the model and accessories, but it generally ranges from $5,000 to $20,000.
Identification
The Bio-Rad iCycler IQ is a real-time PCR (polymerase chain reaction) instrument used for DNA analysis. The instrument has a white and grey exterior, and its dimensions are 17 inches by 21 inches by 22 inches. The iCycler IQ has a graphical user interface on its front panel, with a color display and a set of buttons for control. The Bio-Rad logo is visible on the front panel of the instrument.
The iCycler IQ has a sample block that can accommodate up to 96 tubes or plates, and it uses interchangeable thermal cycling modules to perform PCR reactions. The thermal cycling modules are designed to fit into the sample block and are available in various formats to support different PCR applications. The iCycler IQ also has a heated lid to prevent condensation during the PCR reaction.
Technical Specifications
- Input Power
- 100–250 VAC ± 10% 50–60 Hz
- 250 VA max., 95W typical
- Environmental
- Operating temperature 15–30°C
- Storage temperature -20–30°C
- Humidity 0–90%, non-condensing
- Descriptive, Optical Module
- Size width 12.2” (31. cm)
- height 7” (17.8 cm)
- depth 17” (43.2 cm)
- Weight 15 lbs (6.8 kg) net max
- Power Supply Size width 3.75” (9.5 cm)
- height 2.56” (6.5 cm)
- depth 7.4” (18.8 cm)
- Power Supply Weight 2 lbs (0.9 kg) net max
- Data communications bidirectional PC parallel port
- Regulatory Compliance
- TUV
- CE
Source: iCycler iQ™ Instruction Manual provided by Bio-Rad
