Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background and Identification
The Biochem MicroSpan 3040G is a pulse oximeter sold by Biochem International, Inc. Biochem is a manufacturer and distributor of primarily non-invasive real-time patient monitoring systems. The MicroSpan 3040G model is designed as a portable and compact pulse oximeter that non-invasively monitors the patient’s blood oxygen saturation levels and pulse rate in real-time.
Pulse rate and saturated oxygen level information are displayed by the MicroSpan 3040G on its liquid crystal display (LCD). The LCD features electroluminescent (EL) backlighting. System messages, saturated oxygen levels, pulse rate, and pulse signal strength are displayed on the screen. The device also produces an audible beep with each of the patient’s pulse beats. This model produces a lower-pitched double beep when it detects a decrease in the patient’s saturated oxygen level. Users can adjust the high and low alarm limits for the pulse rate and saturated oxygen level. The beep function can also be adjusted or stopped by the user.
The Biochem MicroSpan 3040G pulse oximeter is powered either by its internal battery or from the AC line.
Technical Specifications
Display: LCD with electroluminescent backlight: large digital display of SaO2 and Pulse Rate. Continuous display of high/low alarm limits. Pulse strength activity logarithmic bar graph.
SaO2: User selectable 8, 4, or 16 beat average
- Range: 0-100%
- Accuracy:
- +/- 2% at 70-100%
- +/-. 3% at 50-69%
- Alarm Ranges:
- Low : 50-99% (in 1% steps) and OFF
- High: 50-100% (in 1% steps) and OFF
Pulse Rate: 8-second pulse rate averaging with 4 or 8 beat Sa02 averaging. 16-second pulse rate averaging with 16 beat Sa02 averaging.
- Range: 30-254 bpm
- Accuracy: +/- 2% at 30-100 bpm
- Alarm Ranges:
- Low: 5-195 (in 5 bpm steps) and OFF
- High: 5-250 (in 5 bpm steps) and OFF
Inputs/Outputs:
- Digital: Serial - Sa02, Pulse Rate, Signal Strength, Plethysmogram, status indication, alarm settings, and trend data in response to single-character commands. Can output 9-hour trend of Sa02, pulse rate, pulse strength, and event data.
- Analog:
- Sa02: 0-100% = 0-1.00 VDC
- Pulse Rate: 30-254 bpm = 0.30-2.54 VDC
- Plethysmogram: 0-2.55 VDC. Centered at 1:28: VDC.
Power Requirements:
- AC Input:
- 115 VAC 50/60Hz 0.2 A
- 230 VAC 50/60Hz 0.1 A
- Battery: 4 to 5-hour operation with 10-hour recharge.
- Dimensions:
- Height = 4"
- Width = 6.5"
- Depth = 9.5"
- Weight: 4 lbs. 8 oz.
Additional Information
Biochem MicroSpan 3040G Pulse Oximeter Operator’s Manual
Biochem MicroSpan 3040G Product Page
