Air Filter
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you are having issues with your Bissell Air180 and need additional help, here is the troubleshooting page.
Background
- Air purifiers stem from the simplest and earliest form of combat to air pollution.
- The Bissel air 180 is a three-stage filtration air purifier. The Bissel Air180(model number 3496A) was released in 2022 and is a household device used to purify the air in your living room, kitchen, bedroom, basement, or wherever in your home. The device has four buttons on the panel
- The Bissell company is a family-owned business that started in 1876 developing cleaning tools designed to keep living environments up to the highest standards.
Identification
- Captures 99.97% of particles of 0.3 microns that help to remove airborne allergens like dust, pollen, smoke, etc. resulting in cleaner and safer air
- 360Complete 3-in-1 filter that collects pollutants and irritants from every side and all around a room.
- With three air changes per hour, BISSELL air180 filters rooms that are 457 square feet. With multi-layer filtration that consists of a pre-filter, activated carbon filter, and a HEPA filter, you can capture large and tiny particles, household aromas, pet scents, and volatile organic compounds (VOCs).
- The elimination of airborne allergens and irritants such as dust, pet dander, pollen, and smoke from wildfires, cooking, and smoking is made easier with the use of medical-grade HEPA filters, which collect 99.97% of particles 0.3 millimeters and smaller.
- The activated carbon in the filter is intended to capture gases, volatile organic substances (VOCs), and normal household odors, such as those generated by pets, cooking, and smoke.
Specifications
- Product Weight: 14 Pounds
- Item model number: 3496A
- Color: White
- Manufacturer: Bissell
- Filter Type: HEPA & Carbon Filters
- Control Method: Touch
- Power Source: Ac/dc
