1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
MM575
Background
The Black & Decker MM575 is an electric lawn mower designed for efficient cutting and mulching of grass. It features a 12-amp motor, which provides more power compared to the 9-amp motor of the MM275 model. This extra power helps the MM575 cope better with slightly overgrown lawns. The mower has a standard 18-inch cutting deck that cuts a sufficient amount of grass on each pass to get your lawn cut fairly quickly. The MM575 is easy to use and requires very little maintenance, making it a popular choice among homeowners.
Technical Specifications
- Motor: 12 Amps
- Deck Size: 18 inches
- Cutting Modes: Mulch, Discharge or Bag (Optional)
- Height Adjustment Type: Single Lever
- Cutting Heights: 1 - 3.5 inches
- Weight: 41 lbs
