2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
53542
Background
Blue Max 53542 is a gasoline-powered pole saw designed for trimming trees and foliage out of reach. Its 32.6 CC 2-Cycle Gasoline Engine offers ample torque, and the fuel primer eliminates air from the carburetor. The saw's 10-inch Bar & Cutting Chain (3/8" Pitch) accommodates larger diameter branches. It also features an automatic clutch for reliable starting and an anti-vibration system for increased comfort and reduced fatigue. The telescopic pole extends up to 101 inches, facilitating access to high branches.
Technical Specifications
- Engine type: 2-stroke engine, air-cooled, chrome cylinder
- Engine power (max.): 0.85 kW/ 1.14 HP
- Displacement: 32.6cc
- Engine idle speed: 3400 RPM
- Max. engine speed: 9500 RPM
- Max. cutting length: 245 mm
- Weight with cutter bar and chain: 7.6 kg
- Chain: 10”, 3/8”, 0.050”
- Ignition: Electronic
- Drive: Centrifugal clutch
- Tank capacity: 825 ml
- Spark plug: L7T
- LpA sound pressure level: 93,9 dB(A)
- KpA uncertainty: 2,5 dB
- LWA sound power level: 108,2 dB(A)
- KWA uncertainty: 2,5 dB
- Extended Length: 101"
- Weight: 10 Pounds
- Consumer Warranty: 1 Year
- Product Length: 106 Inches
- Product Width: 10.3 Inches
- Product Height: 29.5 Inches
- Power Type: Gas
Warranty
Blue Max 53542 comes with a 1-year consumer warranty.
