1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
SN 350-34 C
Background
The Bosch Nailer SN 350-34 C is a powerful and versatile tool designed for fastening materials such as wood, plastic, and metal. This nailer operates on compressed air and features a dual-mode trigger that allows for both sequential and contact firing. With an adjustable depth control, this nailer can be set to accommodate various nail sizes and depths. The SN 350-34 C can drive up to 3-1/2 inch nails, making it ideal for framing, decking, and other heavy-duty construction projects.
Bosch is a well-known and respected brand in the power tool industry, and the SN 350-34 C is no exception.
Identification
The Bosch Nailer SN 350-34 C is a handheld power tool with a distinctive gun-like appearance, featuring a long barrel and a curved handle. The model number, serial number, and manufacturing date can be found on a label affixed to the side of the tool. The nailer is powered by compressed air and can drive up to 3-1/2 inch nails, making it ideal for a variety of heavy-duty construction projects. The Bosch Nailer SN 350-34 C is also designed for safety and convenience. The tool features a safety lock that prevents accidental firing, as well as a grip that reduces hand fatigue during prolonged use. Its compact and lightweight design also makes it easy to handle and maneuver in tight spaces.
Technical specifications
The Bosch Nailer SN 350-34 C operates on compressed air and features a dual-mode trigger that allows for both sequential and contact firing. This nailer can drive up to 3-1/2 inch nails and has an adjustable depth control to accommodate various nail sizes and depths.
Specifications:
- Weight: 8.4 lbs (3.81 kg)
- Operating Pressure: 70-120 psi (4.8-8.3 bar)
- Nail Length: 2" - 3-1/2" (50-90 mm)
- Nail Diameter: 0.113" - 0.148" (2.87-3.76 mm)
- Magazine Capacity: 84 nails
- Dimensions: 13.7" L x 20.7" H x 5.6" W (34.8 cm x 52.6 cm x 14.2 cm)
