2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
0611236739VS
Background
The Bosch 11236VS is a 7.5 amp electric rotary hammer introduced in 1999 by the German company Robert Bosch GmbH. It is designed to drill and chisel into materials such as concrete, masonry, brick, and stone.
The rotary hammer operates at 120 volts with a maximum of 850 watts. It features variable speed motor ranging from 0 to 850 RPM, and an impact rate of 0 to 3,900 BPM. Its impact energy stands at 2.6 ft-lbs. The tool is capable of handling capacities of 1-1/8" concrete, 1/2" steel, 1-1/4" wood, and 4" core bit. The device measures a length of 15-1/4", and weighs 9.3 lbs.
The Bosch 11236VS includes an SDS-Plus chuck for tool-free bit changes. It has three operational modes: rotary hammer, hammer only, and rotation only. The tool is equipped with a variable speed trigger and Vario-Lock with 36 chisel positions. Other features include a padded rear handle, a 360° auxiliary handle with depth gauge, and an integral clutch.
Technical Specifications
- Model Number: 11236vs
- Product Type: Rotary Hammer
- Power: 120 volts, 7.5 amps, 850 watts max
- Motor: Variable speed 0-850 RPM
- Impact rate: 0-3,900 BPM
- Impact energy: 2.6 ft-lbs
- Capacities: 1-1/8" concrete, 1/2" steel, 1-1/4" wood, 4" core bit
- Dimensions: 15-1/4" length
- Weight: 9.3 lbs
Warranty
The Bosch 11236VS rotary hammer comes with a 1 year limited warranty. The specific details regarding what is covered under this warranty are not outlined in the provided document. To claim the warranty, it is generally recommended to contact the manufacturer or retailer directly, although the specific procedure is not mentioned in the context.
