1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
611232739
Background
The Bosch 11232EVS Rotary Hammer is a tool primarily used for heavy chipping and chiseling applications. It is an electric-powered rotary hammer that operates on a 120V power supply and utilizes 6.9 Amps of current. The hammer can reach a no-load speed of up to 1100 RPM and achieves a maximum impact rate of 6,150 beats per minute. This rotary hammer is capable of generating 1.6 ft-lbs of impact energy.
The Bosch 11232EVS Rotary Hammer is equipped with an SDS-Plus chuck system which allows for bit changes without the need for additional tools. It has three different operation modes which include: hammer only, rotate only, and a combined hammer and rotate mode. The hammer also features a vario-lock positioning system that can be adjusted to 36 different angles to optimize the user's working position. The hammer has a maximum drilling capacity of 7/8" in concrete, 1" in wood, and 2-1/2" with core bits. The hammer comes with a depth gauge for making consistent holes. Its design includes an inline grip and an auxiliary side handle for user comfort and control.
Technical Specifications
- Model Number: 11232EVS
- Product Type: Rotary Hammer
- Power Source: Corded Electric
- Voltage: 120V
- Amperage: 6.9 Amps
- No-Load Speed: 0-1100 RPM
- Maximum Beats Per Minute: 6,150 BPM
- Impact Energy: 1.6 ft-lbs
- Chuck Type: SDS-Plus
- Operation Modes: Hammer only, Rotate only, Hammer & Rotate
- Vario-Lock Positioning: 36 different angles
- Weight: 5.6 lbs
- Grip Design: Inline with auxiliary side handle
- Maximum Drilling Capacity (Concrete): 7/8"
- Maximum Drilling Capacity (Wood): 1"
- Maximum Drilling Capacity (Core Bits): 2-1/2"
- Depth Gauge: Yes
- Motor Power: 850W
- Variable Speed: Yes
- Impact Rate: 0-6,150 BPM
Warranty
The Bosch 11232EVS Rotary Hammer comes with a limited warranty that lasts for 1 year from the original purchase date. This warranty covers any defects that may arise due to materials or workmanship. To claim this warranty, proof of purchase is required. However, please note that wear items like brushes, cords, and bits are not included in the warranty coverage.
