2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
RH540M
Background
The Bosch RH540M Rotary Hammer is a specialized drilling tool, powered by a 15 amp motor and a voltage capacity of 120V. It is primarily used for intensive drilling and chiseling tasks, particularly in concrete and masonry materials. The rotary hammer can reach a no-load speed of up to 1,300 RPM and deliver up to 5,800 blows per minute. It boasts an impact energy of 5.4 ft-lbs, making it capable of drilling up to 1-9/16" in concrete, and accommodating a max core bit diameter of 4". The tool measures 18-1/8" in length and weighs 27.3 lbs.
The Bosch RH540M Rotary Hammer is equipped with several features to enhance its performance and user experience. It has a variable speed trigger and reversing switch for controlled speed adjustment, and an SDS-max tool holder for convenient bit changes. It incorporates vibration control technology to reduce the vibration during operation, and an overload protection system to prevent motor damage. The tool also comes with a service minder light to indicate when maintenance is necessary, and a 360-degree adjustable side handle and depth rod for improved control and accuracy. It is particularly useful for applications that involve drilling large diameter holes in concrete, chipping, demolishing concrete, and other fastening tasks. Its hammer-only mode also optimizes it for chiseling applications by eliminating rotation.
Technical Specifications
- Model Number: RH540M
- Product Type: Rotary Hammer
- Motor Power: 15 amps
- Voltage: 120V
- No Load Speed: 0 - 1,300 RPM
- Blows per Minute: 0 - 5,800 BPM
- Impact Energy: 5.4 ft-lbs
- Max Drilling Capacity: 1-9/16" in concrete
- Max Core Bit Diameter: 4"
- Tool Length: 18-1/8"
- Tool Weight: 27.3 lbs
Warranty
The Bosch RH540M Rotary Hammer provides a 1-year limited warranty, which covers any defects in materials and workmanship. It's important to note that this warranty is specifically limited to the original purchaser and does not extend to any damage that may occur due to misuse or improper maintenance of the product. In order to claim the warranty, users should retain their purchase receipt as proof of purchase and contact the manufacturer or retailer in the event of any covered defect or issue.
