2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
RH850VC
Background
The Bosch Rotary Hammer 3611B is a corded electrical tool, primarily intended for drilling and chiseling tasks. It operates using a 120V power supply, draws 13.5 amps of current, and utilizes 850W of power. The tool has a significant impact energy of 7.6 ft-lb, which is facilitated by its two operational modes: rotary hammer and hammer-only. The rotary hammer 3611B also incorporates a feature for variable speed control, allowing the user to adjust the speed according to the task at hand.
This rotary hammer includes a special function known as Vario-lock. This feature provides the user with the ability to select from 12 different chisel positions by rotating the chisel, optimizing the working angle in hammer-only mode. The maximum capacity of the chuck is 13mm. The tool, which is blue and black, weighs 18.5 lb and measures 25.4 x 16.9 x 6 inches. It is designed and manufactured in Germany.
Technical Specifications
- Model Number: 3611B
- Power Source: Corded electric
- Voltage: 120V
- Amperage: 13.5A
- Power: 850W
- Impact Energy: 7.6 ft-lb (EPTA)
- Max Chuck Capacity: 13mm
- Modes: Rotary hammer, hammer-only
- Variable Speed: Yes
- Weight: 18.5 lb
- Dimensions: 25.4 x 16.9 x 6 in
- Color: Blue/Black
Warranty
The Bosch RH745 rotary hammer is covered by a 1-year manufacturer's warranty. This warranty starts from the date of purchase and includes protection against defects in materials and workmanship. Accompanying this warranty is a 30-day money-back guarantee. To claim this warranty, you would need to contact the manufacturer, Bosch, directly. It's advisable to keep your proof of purchase as it might be required during the warranty claim process.
