1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
TS2000
Background
The Bosch Stand Assembly TS2000 (2016) is a stand device, designed to hold table saws from Bosch, as well other table saws from other known brands. This assembly is easy to unload off a vehicle and to unfold in a few seconds to start using the table saw attached, and easy to fold back up and roll back onto a vehicle for the next job.
This product was released by Bosch in 2016, and was made in mind for carpenters or workers who are on the move, and need a stand to be maneuverable and can be compact on the go.
The price for this product varied, mostly if a consumer wants to just have the stand, or if they wanted a table saw with the stand. The prices would be from $250-$650, which is a large price range.
On some reviews, customers leave negative reviews and most explain the front legs of the stand tend to collapse or bend, while having a table saw attached.
This model of the stand assembly was replaced by the Bosch Stand Assembly TS2100, where it was made with more structural integrity and not prone to collapse, as an improvement from consumer reviews.
Identification
This device is a foldable stand with 2 black wheels and the legs at an angle to provide stability. The table part of the product is marked with the Bosch signature blue color, with a red tab at an end to signify a safety marker for attachments and a rubber black slip-on handle, and most notable the Bosch logo on the table. With the legs and the rest of the stand will be in a steel metal color with no additional painting or marking. On the table, it is not a flat surface, there is a square hole in the middle, mostly for installing a saw onto the product and need some pace in the middle to adjust.
Technical Specifications
Dimensions:
Height: 24-1/2"
Material: 1.5mm Steel
Weight (lbs.): 53
Bosch 4100 DG-09 Product Manual (Note: This hyperlink is linked to the similar product for this device page, the hyperlink does contain the information for the dimensions of the Stand Assembly 2000.)
Additional Information
Bosch Stand Assembly 2000 (2016)
Bosch TS2100 Gravity-Rise Wheeled Low-Stance Table Saw Stand
