BL Touch Install
1 Answer 0 Score |
How to calibrate touch screen |
2 Answers 0 Score |
Nozle hits the bed |
1 Answer 0 Score |
I need help in replacing my nozzle and bowden tube in printer |
1 Answer 0 Score |
Why won't the 3 d filament feed? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Specifications
- Model: CR-10S Pro
- Printing Method: FDM (Fused Deposition Molding)
- Printing Size: 300x300x400mm
- Printing Accuracy: ±0.1mm
- Nozzle Diameter: 0.4mm standard
- Hot End Type: ?
- Extrusion Temperature: ≤260℃
- Bed Temperature: ≤110℃
- Printing Speed: ≤180mm/s
- Working Mode: USB/micro SD card
- Slice Software: Cura, Simplify3D, Repetier-Host
- Power Supply Input: 110V/220V AC, 50/60 Hz
- Output: DC 24V
- Filament: 1.75mm PLA, ABS, Wood, TPU, Gradient color, carbon fiber, etc.
- Weight: 13.1kg
- Frame dimensions: 490x600x615 mm
