1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
919.15234
Background
The Craftsman Air Compressor 919.152340 is a compact, single-cylinder air compressor designed for a variety of applications. Manufactured by Ingersoll Rand for Sears under the Craftsman brand, this compressor is permanently lubricated, eliminating the need for oil addition and ensuring the delivery of oil-free air. It is equipped with an adjustable pressure valve that controls the amount of pressure going from the air compressor to the accessory, allowing for pressure settings between 10 and 125 P.S.I.
The compressor is versatile, capable of operating many air-operated tools and accessories, including inflators, blow guns, spray guns, air brushes, caulking guns, and etchers. It is also compatible with power tools designed for short burst operation, such as impact wrenches, nailers/staplers, drills, and nut drivers. This makes it suitable for a range of tasks, from household jobs like inflating tires and painting furniture, to more detailed work like etching wood or glass, and even certain automotive and home improvement projects.
Technical Specifications
- Model Number: 919.152340
- Product Type: Air Compressor
- Design: One cylinder, compact, permanently lubricated compressor
- Weight: Ultra light for added mobility
- Air Hose: 1/4" x 15' with integral pressure adjusting valve
- Pressure Adjusting Valve: Can set approximate pressure between 10 and 125 P.S.I.
- Air Delivery: Compatible with many air tools, including inflators, blow guns, spray guns, air brushes, caulking guns and etchers
- Operation: Operates many accessories, check the pressure and flow rating recommended by the accessory manufacturer
- Accumulator Tank: Provides additional volume of compressed air necessary to operate a wide variety of air tools (not included on some models)
- Safety: Equipped with a relief (pop-off) valve to prevent an overpressure condition in the tank
- Power: Powered by a motor
- Lubrication: Permanently lubricated design, no need to add oil.
Warranty
The Craftsman Air Compressor 919.152340 comes with a full one-year warranty. If the air compressor fails due to a defect in material or workmanship within one year from the date of purchase, it can be returned to the nearest Sears Repair Center throughout the United States, and Sears will repair it free of charge. If the product was purchased from Orchard Supply Hardware, it should be returned to the nearest Orchard store for free repair.
However, if the air compressor is used for commercial or rental purposes, the warranty applies for only ninety days from the date of purchase. This warranty provides specific legal rights, and you may have other rights which vary from state to state.
