2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
919.16734
Background
The Craftsman Air Compressor 919.167340 is a portable, single-stage air compressor manufactured by Ingersoll Rand for Sears. It operates on a 120V/60HZ single-phase voltage and requires a minimum branch circuit of 15 amps. The air compressor has a maximum developed brake horsepower (BP) of 6, with a bore of 2.375" and a stroke of 1.35". It has an air tank capacity of 33 and operates within an approximate cut-in and cut-out pressure of 120 and 150 respectively. The air compressor has a standard cubic feet per minute (SCFM) of 8.6 at 40 psig and 6.4 at 90 psig.
The Craftsman Air Compressor 919.167340 is equipped with several features that enhance its functionality and ease of use. It has an On/Auto/Off switch, a pressure switch, a safety valve, an outlet pressure gauge, a tank pressure gauge, a regulator, and a universal quick-connect body. The pressure switch automatically starts and stops the motor based on the air tank pressure. The regulator controls the air pressure shown on the outlet pressure gauge. The universal quick-connect body accepts the three most popular styles of quick-connect plugs: Industrial, automotive (Tru-flate), and ARC. It also has a drain valve located at the base of the air tank to drain condensation at the end of each use. The air compressor also includes a cooling system that helps keep the unit from overheating during extended use.
Technical Specifications
- Model Number: 919.167340
- Product Type: Air Compressor
- Max. Developed BP: 6
- Bore: 2.375"
- Stroke: 1.35"
- Voltage-Single Phase: 120V/60HZ
- Minimum Branch Circuit Requirement: 15 amps
- Fuse Type: Time Delay
- Air Tank Capacity: 33
- Approx. Cut-In: 120
- Approx. Cut-out: 150
- SCFM @40 psig: 8.6
- SCFM @ 90 psig: 6.4
Warranty
The Craftsman Air Compressor 919.167340 comes with a full one-year warranty. This warranty covers any defects in material or workmanship. If the air compressor fails due to these issues within one year from the date of purchase, you can return it to the nearest Sears Repair Center throughout the United States, and Sears will repair it free of charge. If the product was purchased from Orchard Supply Hardware, you should return it to the nearest Orchard store for a free repair.
However, if the air compressor is used for commercial or rental purposes, the warranty period is reduced to ninety days from the date of purchase. This warranty gives you specific legal rights, and you might have other rights depending on your state's laws. For any queries or concerns, you can reach out to Sears, Roebuck and Co., Dept. 817WA, Hoffman Estates, IL 60179.
