2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
919.16738
Background
The Craftsman Air Compressor 919.167380 is a tank-mounted air compressor designed to provide a source of compressed air for various applications. Manufactured by Ingersoll Rand for Sears under the Craftsman brand, this air compressor operates on a single-phase 120V power supply. It has a running horsepower of 1.1 and an air tank capacity of 17 gallons. The compressor's bore measures 1-7/8 inches, while the stroke measures 1-1/4 inches.
The air compressor has a minimum branch circuit requirement of 15 amps and uses a time delay fuse type. It operates within a cut-in pressure of approximately 120 psi and a cut-out pressure of approximately 150 psi. The compressor delivers 4.3 SCFM (Standard Cubic Feet per Minute) at 40 psig (pounds per square inch gauge) and 3.3 SCFM at 90 psig, as tested per ISO 1217. This air compressor is suitable for various tasks, including powering air tools, inflating tires, and other applications that require compressed air.
Technical Specifications
- Model Number: 919.167380
- Running Horsepower: 1.1
- Bore: 1-7/8 inches
- Stroke: 1-1/4 inches
- Voltage: Single Phase 120V
- Minimum Branch Circuit Requirement: 15 amps
- Fuse Type: Time Delay
- Air Tank Capacity: 17
- Approximate Cut-In: 120
- Approximate Cut-Out: 150
- SCFM @40 psig: 4.3
- SCFM @90 psig: 3.3
- Continuous Running Capability: Yes
- Recommended Duty Cycle: 50%-75% (should not run more than 30-45 minutes in any given hour)
Warranty
The Craftsman Air Compressor model number 919.167380 comes with a full one-year warranty. This warranty covers any defects in material or workmanship. If the air compressor fails due to these reasons within one year from the date of purchase, Sears will either repair or replace it for free. To claim the warranty, you can contact your nearest Sears Service Center at 1-800-4-MY-HOME to arrange for repair, or you can return the air compressor to the place of purchase for replacement. However, if the air compressor is used for commercial or rental purposes, the warranty only applies for ninety days from the date of purchase. This warranty provides you with specific legal rights, and you might have other rights depending on your state.
