2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
921.16923
Background
The Craftsman Air Compressor 921.169230 is a product designed and manufactured by Midwest Air Technologies Inc. for Sears under the Craftsman brand. As an air compressor, its primary function is to convert power, using an electric motor or gasoline engine, into potential energy stored in pressurized air. This pressurized air is then used to power various tools and equipment.
The compressor features a 10-gallon tank and a 1 horsepower oil-lubricated motor. It includes a tank pressure gauge, which indicates the reserve air pressure in the tank, and a regulator that controls the outgoing air pressure to the tool. The compressor also has a quick connect feature for attaching and removing the air hose. Other features include an air intake filter, which provides clean air to the pump, an oil fill cap, a tank safety valve, a pressure switch, and a tank drain valve. The compressor is designed for durability, reliability, and repairability, making it a long-lasting tool for various uses.
Technical Specifications
- Model Number: 921.169230
- Product Type: Air Compressor
- Pump: Oil-lube direct drive
- Motor: 1.0 HP (Induction)
- Bore: 1.65"
- Stroke: 1.26"
- Voltage Single Phase: 120 VAC
- Minimum Circuit Requirement: 15 Amps
- Air Tank Capacity: 10 Gallons
- Cut-in Pressure: 105 PSI
- Cut-out Pressure: 135 PSI
- SCFM @ 90 PSI: 2.4
- Oil Capacity: 90 mL or 3 oz.
- Oil Type: SAE 30 Non-detergent Semi-Synthetic
- Duty Cycle: 50%
Warranty
The warranty for the Craftsman Air Compressor 921.169230 is a one-year full warranty from the date of purchase. This warranty covers any defects in material or workmanship. If a defective product is found, it will receive free repair or replacement if repair is unavailable. To claim the warranty, you can visit the website www.craftsman.com for more details on warranty coverage and how to receive free repair or replacement. It is important to note that this warranty is void if the product is used for commercial services or rented to another person.
