2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.794801
Background
The Craftsman Blower 316.794801 is a durable, air-cooled, 4-cycle engine blower, designed for outdoor use. It has a displacement of 1.95in.3(32cc) and operates at a speed of 6,500-7,500 rpm while idling at a speed of 3,800-4,400 rpm. The blower uses an electronic ignition system with a rocker switch and has a manual spring return throttle. Its fuel capacity is 26 oz (769 ml) and it uses unleaded fuel. The blower is equipped with a diaphragm, all-position carburetor, and a muffler which is baffled with a guard.
The Craftsman Blower 316.794801 has a number of features designed for user comfort and convenience. These include a handle, suspension system, shoulder support, and waist support. The blower also has control features such as an on/off control, cruise control, and a trigger. It is equipped with a primer bulb for easy starting and a nozzle for directing the airflow. Other components of the blower include a gas tank, elbow tube, starter rope, and an air filter cover.
Technical Specifications
- Model Number: 316.794801
- Product: Craftsman Blower 316.794801
- Product Type: Blower
- Engine Type: Air-Cooled, 4-Cycle
- Displacement: 1.95in.3(32cc)
- Operating RPM: 6,500-7,500 rpm
- Idle Speed RPM: 3,800-4,400 rpm
- Ignition Type: Electronic
- Ignition Switch: Rocker Switch
- Valve Clearance: 0.003-0.006 in.(0.076-0.152 mm)
- Spark Plug Gap: 0.025 inch(0.635 mm)
- Lubrication: SAE30 Oil
- Crankcase Oil Capacity: 3.04 oz (90 ml)
- Fuel: Unleaded
- Carburetor: Diaphragm, All-Position
- Starter: Spring Assist Starting TM Auto Rewind
- Muffler: Baffled with Guard
- Throttle: Manual Spring Return
- Fuel Tank Capacity: 26 oz (769 ml)
Warranty
The warranty for the Craftsman Blower 316.794801 is a two-year warranty. The warranty covers the evaporative emission control system, which includes parts such as carburetors, fuel tanks, fuel lines, fuel caps, valves, canisters, filters, vapor hoses, clamps, connectors, and other associated components. If any evaporative emission-related part on the equipment is defective, Sears will repair or replace the part. As the owner, you are responsible for performing the required maintenance listed in the owner's manual. It is recommended to retain all receipts for maintenance, although Sears cannot deny warranty solely based on the lack of receipts. If there is a warranty claim, you should contact Sears at 1-800-4-MY-HOMEĀ®. The warranty repairs should be completed within a reasonable amount of time, not exceeding 30 days.
