2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.794
Background
The Craftsman Blower 316.794000, made by RYOBI, is a gas-powered blower that is equipped with a 27cc engine. This air-cooled, 2-cycle engine allows the blower to reach an operating RPM between 6,900 to 7,200, pushing air at a speed of up to 150 miles per hour and a volume of up to 500 cubic feet per minute. It features an electronic ignition system and is controlled by a manual spring return throttle. The fuel tank has a 20-fluid ounce capacity.
The blower is designed with a shoulder support and suspension system, which makes it easier to carry during operation. The unit comes with a flare nozzle, offering concentrated air flow. It has a spark arrestor that is factory-equipped. It can be started using the Incredipull auto rewind starter, or with the optional power start feature. The blower's body also features a built-in stand.
Technical Specifications
- Model Number: 316.794000
- Product: Craftsman Blower 316.794000
- Product Type: Blower
- Engine Type: Air-Cooled, 2-Cycle
- Engine Displacement: 27 cc
- Idle Speed RPM: 3,200-4,400 rpm
- Operating RPM: 6,900-7,200 rpm
- Maximum MPH: up to 150
- Maximum CFM: up to 500
- Ignition Type: Electronic
- Ignition Switch: Rocker Switch
- Spark Plug Gap: 0.025 in. (0.635 mm)
- Lubrication: Fuel/Oil Mixture
- Fuel/Oil Ratio: 40:1
- Carburetor Type: Diaphragm, All-Position
- Starter Type: Incredipullâ„¢ Auto Rewind
- Muffler Type: Baffled with Guard
- Throttle Type: Manual Spring Return
- Fuel Tank Capacity: 20 oz. (591 ml)
Warranty
The Craftsman Blower 316.794000 comes with a 3-year full warranty against any defects in material or workmanship. Within this period, if the product is found to be defective, it will be repaired or replaced free of charge, depending on the availability of repair services. To claim the warranty, you can visit the website www.craftsman.com for details on warranty coverage and the process to obtain repair or replacement. It is important to note that the warranty covers only defects in material and workmanship and does not include expendable items like filters or spark plugs that can wear out within the warranty period. Additionally, the warranty does not cover product damage resulting from user attempts at modification or repair, product accessories, accidents, failure to operate or maintain the product according to instructions, preventive maintenance, or repairs due to improper fuel mixture or contaminated fuel. The warranty is provided by Sears Brands Management Corporation and grants specific legal rights, which may vary from state to state.
