2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.36038
Background
The Craftsman Blower 358.360380, manufactured by Poulan/Weedeater for Sears under the Craftsman brand, is a gasoline-powered, 2-cycle chainsaw. The product is designed with a range of features to aid in operation and control. A key component is the ON/STOP switch which is used to halt the engine. The engine speed is controlled by the throttle trigger which can only be squeezed when the throttle lock-out has been pressed. This feature helps prevent accidental triggering. The CHOKE/FAST IDLE LEVER is used to set the choke and fast idle for cold starting or after refueling, while the PRIMER BULB circulates fuel to the carburetor for quicker starting.
The chainsaw also includes a chain brake, designed to stop the chain if kickback occurs. This feature activates automatically in the event of kickback and can be manually activated by pushing the front hand guard forward. It is disengaged by pulling the front hand guard back towards the front handle. The chainsaw is also equipped with a chain tension feature. It is normal for a new chain to stretch during the first 15 minutes of operation, so frequent checks of chain tension are recommended.
Technical Specifications
- Model Number: 358.360380
- Product: Craftsman Blower 358.360380
- Product Type: Blower
- Engine Type: 2-Cycle Gasoline
- Engine Size: 2.6 cu.in./42cc
- Bar Length: 18 inches
- Safety Features: Chain Brake, Front Hand Guard
- Assembly: Required
- Operation: Gas-powered
- Fuel Type: Gasoline with 2-cycle engine oil mixture
Warranty
The warranty for the Craftsman Blower 358.360380 is a full one-year warranty. Within this period, Sears will provide free repair for any defect in material or workmanship, as long as the blower is maintained, lubricated, and tuned up according to the instruction manual. However, the warranty does not cover expendable parts such as the bar, chain, spark plug, and air filter, which may become worn during normal use. To claim the warranty, customers can contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs can be provided at all Sears Service Centers.
