3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.794701
Background
The Craftsman Blower 358.794701, manufactured by Poulan/Weedeater for Sears, is a versatile outdoor tool that serves both as a blower and vacuum. The blower function is suitable for sweeping debris or grass clippings from driveways, sidewalks, patios, and similar areas. It can also blow grass clippings, straw, or leaves into piles, around joints, or between bricks. The vacuum function, on the other hand, is designed to pick up dry material such as leaves, grass, small twigs, and bits of paper.
The Craftsman Blower 358.794701 is designed for ease of use and reliable operation. The user can operate the unit at high speed for the best results during vacuum use. The vacuum tube should be kept about an inch above the ground for optimal performance. The unit is made with materials and workmanship intended to withstand normal use and wear and tear. It's recommended to check the air intake opening, blower tubes, and vacuum tubes frequently to ensure proper functionality and extend the lifespan of the product.
Technical Specifications
- Model Number: 358.794701
- Product: Craftsman Blower 358.794701
- Product Type: Blower
- Power Source: Gasoline powered
- Engine Type: 2-cycle
- Engine Size: 25cc/1.5 cu.in.
- Maximum Air Speed: 200 MPH
- Maximum Air Volume: 430 CFM
Warranty
The Craftsman Blower 358.794701 comes with a two-year full warranty from the date of purchase. This warranty covers any defects in material or workmanship and provides free repair or replacement if repair is unavailable. To claim the warranty, you can visit the website www.craftsman.com for more details on warranty coverage and how to obtain repair or replacement. It is important to note that the warranty only covers defects in material and workmanship and does not include expendable items that can wear out within the warranty period, product damage resulting from user attempts at modification or repair, repairs necessary due to accidents or failure to operate/maintain the product properly, preventive maintenance, or repairs due to improper fuel mixture or contaminated/stale fuel. The warranty is void if the product is used for commercial services or rented to another person. Sears Brands Management Corporation, located in Hoffman Estates, IL 60179, provides this warranty and it gives specific legal rights to the customer.
