3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358794731
Background
The Craftsman Blower 358.794731 is a gasoline-powered machine that is principally used for moving and gathering leaves, grass, small twigs, and bits of paper. Manufactured by Poulan/Weedeater for Sears under the Craftsman brand, the engine of this blower runs on a mixture of unleaded gasoline and synthetic 2-cycle air-cooled engine oil at a ratio of 40:1. The blower is certified to be emissions compliant and is capable of generating air speeds of up to 200 miles per hour and air volume of up to 430 cubic feet per minute.
This blower features a 25cc, 1.5 cu.in., 2-cycle engine, which offers a robust and reliable performance for various outdoor cleaning tasks. The blower can also function as a vacuum, aimed at picking up dry material such as leaves, grass, small twigs, and bits of paper. However, it should not be used to vacuum hard or sharp objects, like stones, gravel, metal, or broken glass, to avoid damage to the blower's impeller. Moreover, it's recommended to operate the blower at the lowest possible throttle speed to complete the job, reducing noise levels and conserving fuel.
Technical Specifications
- Model Number: 358.794731
- Product: Craftsman Blower 358.794731
- Product Type: Blower
- Engine Type: 2-Cycle Gasoline Powered
- Engine Displacement: 25cc/1.5 cu.in.
- Maximum Air Speed: 200 MPH
- Air Volume: 430 CFM
Warranty
The Craftsman Blower 358.794731 comes with a two-year full warranty. This warranty covers any defects in material or workmanship that may arise within two years from the date of purchase. If you experience any issues with the product during this period, you can have it repaired for free by returning it to any Sears store, Sears Service Center, or other Craftsman outlet in the United States. In case repair proves to be impossible, the product will be replaced. It is important to note that the warranty does not cover the spark plug and air cleaner, as these are considered expendable parts that can wear out in less than two years. Additionally, if the blower is used for commercial or rental purposes, the warranty is limited to only 30 days from the date of purchase. To claim the warranty, you can contact any Sears Service Center or call 1-800-469-4663.
