3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.794763
Background
The Craftsman Blower 358.794763, manufactured by POULAN/WEEDEATER for Sears, is a gasoline-powered device designed for blowing and vacuuming. One of its notable features is the mulching blades, which when used with the vacuum attachment, can automatically reduce debris at a ratio of up to 16:1. This capability makes it particularly useful in areas with heavy leaf or debris accumulation.
The blower is equipped with numerous controls for effective operation. The STOP switch, for instance, is used to stop the engine. The THROTTLE TRIGGER allows the user to select the desired engine speed, while the THROTTLE POSITION LEVER is designed to set the engine speed during blower use. The PRIMER BULB removes air from the carburetor and fuel lines, filling them with fuel for easier engine start. The START LEVER aids in supplying fuel to the engine for starting. The device is also certified to be emissions compliant, making it an environmentally-friendly choice for outdoor maintenance tasks.
Technical Specifications
- Model Number: 358.794763
- Product: Craftsman Blower 358.794763
- Product Type: Blower
- Product Size: 25cc/1.5 cu.in.
- Engine Type: 2-Cycle
- Maximum Air Speed: 210 MPH
- Maximum Air Volume: 450 CFM
- Fuel Type: Gasoline
- Fuel Mix Ratio: 40:1 (3.2 fluid ounces of oil with 1 gallon of gasoline)
- Safety Features: STOP Switch, Throttle Trigger, Throttle Position Lever, Primer Bulb, Start Lever
- Mulching Feature: Equipped with mulching blades that reduce debris at a ratio of up to 16:1
Warranty
The warranty for the Craftsman Blower 358.794763 is valid for two years from the date of purchase. If the product fails due to a defect in material or workmanship within this period, it can be returned to any Sears store, Parts & Repair Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. However, if the product is used for commercial or rental purposes, the warranty period is reduced to only 90 days. The warranty specifically covers defects in material and workmanship and does not cover expendable items that may wear out during normal use, accidents, failure to operate or maintain the product according to instructions, preventive maintenance, or repairs needed due to improper fuel mixture or contaminated fuel. To claim the warranty, customers can contact Sears Service Centers at 1-800-469-4663 or send an email to emission.warranty@HCOP-emission.com. It is important to note that the warranty provides specific legal rights and additional rights may vary from state to state.
