3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.794944
Background
The Craftsman Blower 358.794944 is a gasoline-powered device known for its durability and longevity. Manufactured by Poulan/Weedeater for Sears under the Craftsman brand, it is a versatile tool that is utilized for blowing and vacuuming debris. The blower is equipped with a throttle lever that allows the user to control the engine speed and stop the engine when necessary. For optimized operation, the blower features a primer button that removes air from the carburetor and fuel lines, filling them with fuel to enable easier engine startup.
Moreover, the blower has a choke lever designed to supply additional fuel to the engine to aid in cold starting. The blower is built to operate at reasonable hours, delivering optimal performance without causing disturbance. It is designed to operate at the lowest possible throttle speed to do the job, thus reducing noise levels. The blower is also beneficial in conserving water as it can be used instead of hoses for many lawn tasks. Despite its powerful performance, the blower maintains a strong focus on reliability and repairability.
Technical Specifications
- Model Number: 358.794944
- Product: Craftsman Blower 358.794944
- Product Type: Blower
- Engine Type: 2-Cycle
- Engine Size: 25cc/1.5 cu.in.
- Air Speed: 200 MPH
- Air Volume: 400 CFM
- Power Source: Gasoline
Warranty
The Craftsman Blower 358.794944 comes with a two-year full warranty. This warranty covers any defects in material or workmanship that may arise within two years from the date of purchase. If the product fails due to such defects, it can be returned to any Sears store, Sears Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. It's important to note that the warranty excludes the spark plug and air cleaner, which are considered expendable parts that can wear out in less than two years due to normal use. Additionally, if the blower is used for commercial or rental purposes, the warranty only applies for the first 30 days from the date of purchase. To claim the warranty, customers can contact any Sears Service Center or call 1-800-469-4663. The warranty statement also mentions that the owner is responsible for performing all required maintenance as outlined in the instruction manual.
