3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.794964
Background
The Craftsman Blower 358.794964 is a gasoline-powered blower and vacuum manufactured by Poulan/Weedeater for Sears under the Craftsman brand. This blower features a 25cc, 2-cycle engine capable of producing wind speeds up to 205 MPH and a volume of 410 Cubic Feet per Minute (CFM), making it suitable for various outdoor cleaning tasks.
This blower is equipped with mulching blades which automatically reduce debris at a ratio of up to 16:1 when the vacuum attachment is used. It is also designed with a throttle lever to adjust the engine speed and a choke lever to supply fuel for cold starting. In addition, it has a primer button that removes air from the carburetor and fuel lines, allowing for fewer pulls on the starter rope during startup. The blower is built for durability and reliability, with components such as the carburetor, ignition system, muffler, and fuel tank designed to comply with emission standards.
Technical Specifications
- Model Number: 358.794964
- Product: Craftsman Blower 358.794964
- Product Type: Blower
- Engine Type: 2-Cycle
- Engine Displacement: 25cc/1.5 cu.in.
- Air Speed: 205 MPH
- Air Volume: 410 CFM
- Mulching Ratio: Up to 16:1
Warranty
The Craftsman Blower 358.794964 comes with a two-year full warranty. This warranty covers any defects in material or workmanship that may occur within two years from the date of purchase. If the product fails due to such a defect, it can be returned for free repair or replacement at any Sears store, Sears Service Center, or other Craftsman outlet in the United States. However, please note that the warranty does not cover expendable parts such as the spark plug and air cleaner, which can wear out from normal use in less than two years. It is important to read the operator's manual carefully and follow all warnings and safety rules before operating the unit to avoid any injuries. The warranty is valid for 30 days from the date of purchase if the blower is used for commercial or rental purposes. For warranty service, you can contact any Sears Service Center at 1-800-469-4663.
