3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79717
Background
The Craftsman Blower 358.797170 is a gasoline-powered device designed to handle a variety of yard cleaning tasks. This blower is equipped with a 25cc, 2-cycle engine, capable of generating an airspeed of 200 MPH and an air volume of 400 CFM. This makes it well-suited for sweeping debris or grass clippings from driveways, sidewalks, and patios, and for blowing grass clippings, straw, or leaves into piles.
In addition to its blowing function, this Craftsman model can also be used as a vacuum, allowing it to pick up dry material such as leaves, grass, small twigs, and bits of paper. In vacuum mode, the device is most effective when operated at high speed and moved slowly back and forth over the material. The vacuum tube should be kept about an inch above the ground for best results. The product is designed to be reliable and durable, requiring regular maintenance for optimal performance.
Technical Specifications
- Model Number: 358.797170
- Product: Craftsman Blower 358.797170
- Product Type: Blower
- Engine Type: 2-Cycle
- Engine Size: 25cc/1.5 cu.in.
- Air Speed: 200 MPH
- Air Volume: 400 CFM
- Power Source: Gasoline
Warranty
The Craftsman Blower 358.797170 comes with a full two-year warranty from the date of purchase. During this warranty period, Sears will repair or replace any defective parts free of charge, as long as the blower is maintained, lubricated, and tuned up according to the instructions in the instruction manual. The warranty covers the repair or replacement of any warranted part, with the exception of blower tubes, spark plug, and air cleaner, which are considered expendable parts and may wear out during normal use. To claim the warranty, owners should contact their nearest authorized service center or call Sears at 1-800-469-4663. Warranty repairs should be completed within 30 days. It's important to note that the warranty does not cover failures caused by abuse, neglect, improper maintenance, or the use of add-on or modified parts.
