4 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.7973, 358.797300
Background
The Craftsman Blower 358.797300, manufactured by Poulan/WeedEater for Sears, is a versatile and reliable gas-powered tool that serves dual functions as a blower and vacuum. The blower function is ideal for sweeping debris or grass clippings from driveways, sidewalks, and patios, or blowing grass clippings, straw, or leaves into piles. The vacuum function is designed for picking up dry material such as leaves, grass, small twigs, and bits of paper, proving especially effective when the unit is operated at high speed.
The unit operates on unleaded gasoline mixed with 2-cycle air-cooled engine oil, providing power for its 2-cycle engine. The throttle lever is used to select the desired engine speed and to stop the engine. The primer button removes air from the carburetor and fuel lines and fills them with fuel, allowing for easier engine start-up. A choke lever aids in supplying fuel to the engine for smooth cold starts. The Craftsman Blower 358.797300 is designed with user comfort and efficiency in mind, featuring an adjustable shoulder strap for vacuum use.
Technical Specifications
- Model Number: 358.797300
- Product: Craftsman Blower 358.797300
- Product Type: Blower
- Engine Type: 2-Cycle
- Engine Displacement: 25cc/1.5 cu.in.
- Air Speed: 185 MPH
- Air Volume: 385 CFM
- Power Source: Gasoline
- Safety Features: Included in the manual
- Assembly: Included in the manual
- Operation: Included in the manual
- Maintenance: Included in the manual
- Parts List: Included in the manual
- Language Options: English, Spanish
Warranty
The warranty for the Craftsman Blower 358.797300 lasts for a period of two years from the initial date of purchase. It covers the repair or replacement of any warranted part at no charge to the owner at an approved Sears servicing center. The warranty does not cover failures caused by abuse, neglect, or improper maintenance. To claim the warranty, you should contact your nearest authorized service center or call Sears at 1-800-469-4663. Warranty services or repairs can be provided at all Sears service centers.
