4 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79755
Background
The Craftsman Blower, model number 358.797550-BLOWER, is a versatile outdoor tool designed for a variety of tasks. This blower is powered by a 25cc, 1.5 cubic inch 2-cycle engine, allowing it to generate wind speeds of up to 200 miles per hour and produce 400 cubic feet per minute of airflow. Manufactured by Poulan/Weedeater for Sears under the Craftsman brand, it runs on unleaded gasoline which needs to be mixed with a good quality synthetic 2-cycle air-cooled engine oil at a ratio of 40:1.
The Craftsman Blower is useful for sweeping debris or grass clippings from driveways, sidewalks, and patios, as well as blowing grass clippings, straw, or leaves into piles or around joints and between bricks. The blower can also be used as a vacuum for picking up dry material such as leaves, grass, small twigs, and bits of paper. For optimal vacuum use, it is recommended to operate the unit at high speed and move slowly back and forth over the material being vacuumed. Despite its powerful performance, it requires regular care and maintenance tasks such as cleaning the unit, inspecting for loose or damaged parts, cleaning the air filter, replacing the spark plug, and checking the muffler mounting screws.
Technical Specifications
- Model Number: 358.797550-BLOWER
- Product Type: Blower
- Engine: 25cc/1.5 cu in. 2-Cycle
- Air Speed: 200 MPH
- Air Volume: 400 CFM
- Fuel: Gasoline
Warranty
The warranty for the Craftsman Blower 358.797550-BLOWER is for a period of two years from the initial date of purchase. The warranty covers the repair or replacement of any warranted part, which will be performed at no charge to the owner at an approved Sears servicing center. It is important for the small off-road engine owner to perform the required maintenance listed in the instruction manual and retain all receipts covering maintenance. Sears recommends contacting the nearest authorized service center or calling Sears at 1-800-469-4663 for any questions regarding warranty rights and responsibilities. In order to claim the warranty, the small off-road engine should be presented to a Sears authorized repair center as soon as a problem exists. Warranty repairs should be completed within a reasonable amount of time, not exceeding 30 days.
