12 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.88816
Background
The Craftsman Electric Snow Thrower 247.888160 is a two-stage, wheel drive snow thrower designed by MTD (Modern Tool and Die) for Sears under the Craftsman brand. It is equipped with a 6.5 horsepower engine that provides the necessary power to operate the auger and impeller, which are the main components responsible for snow intake and expulsion.
The snow thrower is designed to clear a path 24 inches wide, making it suitable for use in a variety of environments, from residential sidewalks and driveways to larger areas such as parking lots. It operates on electric power and incorporates a three-wire extension cord for connection to an electrical outlet. The machine features controls for fast and slow operation, a choke for cold starts, and an ignition key for starting the engine. It also includes controls for stopping the engine and for engaging and disengaging the auger and impeller. The machine is designed to be operated in cold weather and its height can be adjusted to clear different surfaces, such as gravel or crushed rock.
Technical Specifications
- Horse Power: 6.5
- Stage: Two-Stage
- Drive: Wheel Drive
- Model Number: 247.888160
- Product Type: Snow Thrower
Warranty
The Craftsman Electric Snow Thrower 247.888160 comes with a two-year warranty. This warranty covers any defects in material and workmanship, and Sears will repair the snow thrower free of charge during this period. To be eligible for warranty service, the snow thrower must be maintained, lubricated, and tuned up according to the instructions in the owner's manual. However, it's important to note that the warranty only applies if the snow thrower is used for personal purposes and not for commercial or rental purposes. The warranty does not cover expendable items that may wear out during normal use, such as skid shoes, shave plate, and spark plugs. It also does not cover repairs necessary due to operator abuse or negligence. To claim the warranty, you need to return the Craftsman Snow Thrower to the nearest Sears Service Center/Department in the United States. It's worth mentioning that this warranty is applicable only while the product is being used within the United States.
