7 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.88651, 247.886510
Background
The Craftsman Gas Snow Thrower 247.886510 is a gas-powered snow removal tool manufactured by Modern Tool and Die (MTD) for Sears under the Craftsman brand. This dual stage snow thrower is equipped with a 23-inch wide clearing path and a 5 horsepower engine, offering significant snow removal capabilities. This model has an optional electric starter feature that allows it to be started with the push of a button, in addition to the traditional pull-start method.
The Craftsman Gas Snow Thrower 247.886510 is used primarily for clearing snow from driveways, sidewalks, and other outdoor surfaces during the winter months. The machine propels collected snow through a chute, clearing a path as it moves. This snow thrower is designed with a dual stage operation, which means it has an impeller that helps to expel the snow out of the chute, in addition to the auger that pulls snow into the machine. This results in more powerful snow throwing, making this model suitable for areas with heavy snowfall.
Technical Specifications
- Model Number: 247.886510
- Product Type: Gas Snow Thrower
- Snow Thrower Width: 23 inches
- Power: 5 H.P. dual stage
- Starter: Optional electric starter available
- Speeds: 6 forward speeds, neutral, and 2 reverse speeds
- Discharge Chute: Adjustable direction and distance
- Drive Wheels: Adjustable for different operation methods
Warranty
The Craftsman Gas Snow Thrower 247.886510 comes with a limited two-year warranty. This warranty covers any defects in material and workmanship, and Sears will provide free repairs during this period. However, the warranty does not cover expendable items that may become worn during normal use, such as spark plugs, tire chains, and shear pins. It also does not cover repairs that are necessary due to operator abuse or negligence, including bent crankshafts and failure to properly maintain the equipment according to the owner's manual. To claim the warranty, owners can contact the nearest service center/department in the United States. It's important to note that this warranty is only valid while the product is in use in the United States.
