4 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.887791
Background
The Craftsman Gas Snow Thrower 247.887791, a product manufactured by MTD (Modern Tool and Die) for Sears under the Craftsman Brand, is a machine designed to remove snow from areas where it is not wanted. This gas-operated machine functions by throwing the collected snow away from the path it clears, making it ideal for use in residential areas or places with moderate to heavy snowfall.
The Craftsman Gas Snow Thrower 247.887791 is equipped with several features. It has a fuel capacity of 2.3 quarts, allowing for extended periods of operation without refueling. The machine operates with a 5W-30 engine oil type and has an engine oil capacity of 20 ounces. It uses a Torch F6RTC (F6TC) spark plug with a spark plug gap ranging from .020" to .030". As for its emission standards, it is certified to meet the California Air Resources Board (CARB) Tier 2 Emission Standards. This means the machine operates with a relatively low level of emissions. Additionally, the engine of the machine is designed to be compliant for a specific number of operating hours, depending on its displacement, which can be categorized into C = 125 hours, B = 250 hours, and A = 500 hours for engines less than 225 cc displacement. For engines of 225 cc or more, Category C = 250 hours, B = 500 hours, and A = 1000 hours.
Technical Specifications
- Engine Oil Type: 5W-30
- Engine Oil Capacity: 20 ounces
- Fuel Capacity: 2.3 Quarts
- Spark Plug: Torch F6RTC (F6TC)
- Spark Plug Gap: .020" to .030"
Warranty
The Craftsman Gas Snow Thrower 247.887791 comes with a two-year full warranty. This warranty covers any defects in material or workmanship for a period of two years from the date of purchase. If the product is found to be defective, it will receive free repair or replacement if repair is unavailable. However, it is important to note that this warranty is void if the product is ever used while providing commercial services or if rented to another person. To claim the warranty, customers can visit the website www.craftsman.com for warranty coverage details and to obtain repair or replacement. It is worth mentioning that the warranty only covers defects in material and workmanship and does not include expendable items that can wear out within the warranty period, standard maintenance servicing, tire replacement or repair caused by punctures from outside objects, repairs necessary due to operator abuse or negligence, engine cleaning or repairs caused by contaminated fuel, and normal deterioration and wear of exterior finishes or product label replacement.
