Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.8883
Background
The Craftsman Gas Snow Thrower model 247.888300 is a machine designed to displace snow. It is manufactured by MTD (Modern Tool and Die) for Sears under the Craftsman brand. This gas snow thrower is used to clear snow from areas such as driveways, sidewalks, and parking lots. It operates by using a rotating auger to scoop up the snow and an impeller to throw the snow out of its discharge chute.
The snow thrower is powered by a gasoline engine, which requires regular maintenance for optimal performance. The engine uses a spark plug model Torch F6RTC with a gap of .020" to .030". It has an oil capacity of 37 ounces and uses SAE 5W-30 engine oil. The fuel capacity of the machine is approximately 5 quarts. The snow thrower has certain emission standards, certified to meet the California Air Resources Board (CARB) Tier 2 Emission Standards, indicating its compliance with particular emission levels during its operational life.
Technical Specifications
- Model Number: 247.888300
- Product Type: Gas Snow Thrower
- Emissions Durability Period: Certified for 125, 250, or 500 hours of actual engine running time depending on category.
- Air Index: Lower number indicates cleaner engine.
- Emissions Compliance Period: After July 1, 2000, indicates the number of operating hours the engine has been shown to meet Federal emission requirements.
- Engine Oil Type: SAE5W-30
- Engine Oil Capacity: 37 ounces
- Fuel Capacity: Approximately 5 Quarts
- Spark Plug: TorchF6RTC
- Spark Plug Gap: .020" to .030"
Warranty
The warranty for the Craftsman Gas Snow Thrower 247.888300 is a two-year full warranty. This warranty covers any defects in material or workmanship for two years from the date of purchase. If a defective product is found, it will receive free repair or free replacement if repair is not available. However, please note that this warranty only applies for one year if the product is used for commercial services or rented to another person. To claim the warranty, you can visit the website www.craftsman.com for coverage details and to obtain repair or replacement. It is important to note that the warranty covers only defects in material and workmanship and does not include expendable items that can wear out within the warranty period, standard maintenance servicing, tire replacement or repair caused by punctures, repairs necessary due to operator abuse or negligence, engine cleaning or repairs caused by fuel contamination, normal deterioration and wear of exterior finishes, or product label replacement.
