5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.889701
Background
The Craftsman Gas Snow Thrower 247.889701 is a product designed to efficiently remove snow from paths and driveways. Manufactured by MTD for Sears under the Craftsman brand, it operates with a gasoline-powered engine. The engine's emissions are certified to meet the California Air Resources Board (CARB) Tier 2 Emission Standards which categorizes the engine's emissions compliance period based on actual engine running time.
The snow thrower utilizes rotating blades and a rotating auger to scoop and throw snow out of the way. It is equipped with an engine that has an electric starter for easy starting, even in cold weather. The snow thrower is capable of picking up and throwing objects, which aids in the removal of snow. For fuel, the snow thrower has a capacity of 2.3 quarts, and the engine oil capacity is 20 ounces. The spark plug used is a Torch F6RTC with a spark plug gap of .020" to .030". The product is designed for use in outdoor environments and is not suitable for indoor use due to the emission of carbon monoxide from the engine.
Technical Specifications
- Model Number: 247.889701
- Product Type: Gas Snow Thrower
- Engine Oil Type: 5W-30
- Engine Oil Capacity: 20 ounces
- Fuel Capacity: 2.3 Quarts
- Spark Plug: Torch F6RTC
- Spark Plug Gap: .020" to .030"
Warranty
The Craftsman Gas Snow Thrower 247.889701 comes with a full warranty that covers any defects in material or workmanship for a period of two years from the date of purchase. If the snow thrower fails within this time frame, it can be returned to any Sears store, Sears Parts & Repair Service Center, or other Craftsman outlet in the United States for free repair or replacement if repair is not possible. However, it is important to note that this warranty only applies for 90 days from the date of purchase if the snow thrower is used for commercial or rental purposes. The warranty specifically covers defects in material and workmanship and does not cover expendable items that become worn during normal use, standard maintenance servicing, tire replacement or repair caused by external punctures, tire or wheel replacement or repair due to normal wear or improper operation, repairs necessary due to operator abuse or negligence, engine cleaning or repairs caused by contaminated or oxidized fuel, and normal deterioration and wear of exterior finishes or product label replacement. It is recommended to record the model number, serial number, and date of purchase for future reference. To claim the warranty, simply return the product to a designated Sears store or service center.
