12 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
247.889703
Background
The Craftsman Gas Snow Thrower 247.889703 is a snow removal device that is powered by gasoline. This product is manufactured by MTD (Modern Tool and Die) for Sears under the Craftsman brand. It is designed to throw or remove snow from surfaces such as driveways or sidewalks, making it an essential tool for maintaining clear paths during winter months.
The snow thrower utilizes rotating blades to scoop up the snow and a chute to direct the thrown snow to a desired location. It is equipped with a cold start enrichment system, carburetor and internal parts, fuel pump, and fuel tank that contribute to its fuel metering system. Its air induction system includes an air cleaner and an intake manifold. The ignition system consists of spark plugs and a magneto ignition system. The exhaust system includes a catalytic converter and a SAI (Reed valve). The snow thrower also comes with vacuum, temperature, position, time sensitive valves and switches, connectors and assemblies, and an evaporative control system which includes fuel hoses certified for ARB evaporative emission of 2006, fuel hose clamps, tethered fuel cap, carbon canister, and vapor lines.
Technical Specifications
- Engine Oil Type: 5W-30
- Engine Oil Capacity: 20 ounces
- Fuel Capacity: 2.3 Quarts
- Spark Plug: F6RTC
- Spark Plug Gap: .020" to .030"
Warranty
The Craftsman Gas Snow Thrower 247.889703 comes with a two-year full warranty from the date of purchase. This warranty covers any defects in material or workmanship. If the product is found to be defective, it will receive free repair or replacement if repair is unavailable. However, please note that this warranty is void if the product is ever used for commercial services or rented to another person. The warranty does not cover expendable items that can wear out from normal use within the warranty period, such as augers, auger paddles, drift cutters, skid shoes, shave plate, shear pins, spark plug, air cleaner, belts, and oil filter. It also does not cover standard maintenance servicing, oil changes, tune-ups, or tire replacement or repair caused by punctures from outside objects. Additionally, repairs necessary due to operator abuse or negligence, as well as engine cleaning or repairs caused by fuel determined to be contaminated or oxidized, are not covered by the warranty. To claim the warranty, visit the website www.craftsman.com for coverage details and to obtain repair or replacement. It is important to keep a record of the model number, serial number, and date of purchase.
