4 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
536.8814
Background
The Craftsman Gas Snow Thrower 536.881400 is a snow removal device manufactured by Western Tool & Stamping for Sears under the Craftsman brand. This machine is powered by a 4-horsepower engine with a displacement of 190cc, and it utilizes a Champion RJ19LM spark plug or equivalent. It has a fuel capacity of 1.5 quarts of unleaded gasoline, and it requires 5W30 oil for lubrication. The auger, which is the rotating part responsible for picking up snow and throwing it out of the machine, requires regular maintenance to ensure optimal performance and longevity.
The product is designed to clear snow from residential areas like driveways and sidewalks. It operates by sucking in snow through the front auger and then throwing it out via the discharge chute. The snow thrower is also equipped with a control flange that requires lubrication for smooth operation. Regular maintenance of the machine, such as checking and cleaning the spark plug, inspecting the spark arrestor, checking the fuel, and tightening all screws and nuts, can improve its performance and extend its lifespan. After each use, it's recommended to run the machine to clear the auger of snow and to prevent freezing of the auger or controls by removing all snow and slush from the snow thrower.
Technical Specifications
- Horsepower: 4 HP
- Displacement: 190cc
- Bore: 68mm (2.69 in.)
- Stroke: 52mm (2.05 in.)
- Gasoline Capacity: 1.5 quarts (unleaded)
- Oil Capacity: 20 oz (5W30)
- Spark Plug: Champion RJ19LM (Gap .030 in.) or equivalent
- Valve Clearance - Intake: 0.004-0.006 in.
- Valve Clearance - Exhaust: 0.009-0.011 in.
- Armature Air Gap: 0.010-0.014 in.
Warranty
The warranty for the Craftsman Gas Snow Thrower 536.881400 is a limited one-year warranty. Within one year from the date of purchase, Sears will repair any defect in material or workmanship free of charge, as long as the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. However, if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins, or repairs necessary due to operator abuse or negligence. To claim the warranty, the Craftsman Snow Thrower should be returned to the nearest Sears service center in the United States. Please note that this warranty only applies while the product is in use in the United States.
