11 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
536.881851
Background
The Craftsman Gas Snow Thrower 536.881851 is a machine designed for snow removal. It's powered by gasoline and operates via a combination of manual and automatic functions. It features an auger and impeller system for gathering and ejecting snow, a traction drive lever which propels the machine forward and in reverse, a speed shifter lever to control the snow thrower's speed, and a crank assembly to direct the flow of snow.
The machine has a choke control and a primer button for cold starts, as well as a recoil starter handle for manual engine starts. An electric start button can be used for starting the engine with a 120 V electric starter. The snow thrower includes a height adjust skid for adjusting the ground clearance of the auger housing, and a discharge chute that can be adjusted to change the height and direction of the thrown snow. The engine specifications indicate a horsepower of 8.5 and a displacement of 249 cc. The gas capacity is three quarts of unleaded fuel. The snow thrower also includes a safety key required for starting the engine and shear pins designed to break if an object becomes lodged in the auger housing. Regular maintenance, such as change of engine oil, checking and cleaning the spark plug, and inspection of the spark arrestor and fuel, is recommended for improved performance and extended engine life.
Technical Specifications
- Horsepower: 8.5 HP
- Engine Displacement: 249 cc
- Bore: 75 mm (2.970 in.)
- Stroke: 56 mm (2.205 in.)
- Gasoline Capacity: 3 quarts (unleaded)
- Oil Capacity: 18 oz (5W30)
- Spark Plug: Champion RJ19LM or equivalent (Gap .030 in.)
- Valve Clearance (Intake): 0.004-0.006 in.
- Valve Clearance (Exhaust): 0.009-0.011 in.
- Armature Air Gap: 0.010-0.014 in.
Warranty
The Craftsman Gas Snow Thrower 536.881851 comes with a limited two-year warranty. The warranty covers any defects in material or workmanship and is valid for two years from the date of purchase, as long as the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. However, if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. It also does not cover repairs necessary due to operator abuse or negligence, including bent crankshafts and failure to maintain the equipment according to the instructions in the owner's manual. To claim the warranty, you can return the Craftsman Snow Thrower to the nearest Sears Service Center in the United States. It's important to note that this warranty applies only while the product is in use in the United States.
