7 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
536.88467
Background
The Craftsman Gas Snow Thrower 536.884670 is a product designed to assist in the removal of snow. It is powered by a 2-cycle engine, which utilizes a combination of gasoline and oil to operate. The engine is equipped with a recoil starter for manual starting, as well as an electric starter for ease of operation. The snow thrower features a 21-inch clearing width, making it suitable for clearing sidewalks, driveways, and other areas covered with snow.
The snow thrower operates using several controls. These include a choke control for adjusting the air-fuel mixture during starting, and an auger control for managing the rotating blades that scoop up the snow. The thrown snow's direction can be adjusted using a chute control rod. Additionally, the snow thrower is equipped with a primer button which is used to deliver fuel directly to the carburetor, facilitating easier starting in cold conditions. It also features an ignition key for safety.
Technical Specifications
- Engine: 5 hp, 8.46 cu. in. displacement, 2-cycle
- Gasoline Capacity: 1.62 quarts
- Fuel/Oil Mix Ratio: 40:1 (3.2 oz of air-cooled engine 2-cycle oil per 1 gal of gas)
- Spark Plug: Champion RCJ8Y (gap .030 in.)
Warranty
The Craftsman Gas Snow Thrower 536.884670 comes with a two-year limited warranty. This warranty covers any defects in material and workmanship for a period of two years from the date of purchase. To claim the warranty, the snow thrower must be maintained, lubricated, and tuned-up according to the instructions in the owner's manual. If any defect is found within the warranty period, Sears will provide repair services free of charge. However, it is important to note that this warranty does not cover expendable items such as spark plugs, drive belts, and shear pins, which may become worn during normal use. Additionally, this warranty does not cover repairs necessary due to operator abuse or negligence, including bent crankshafts or failure to maintain the equipment according to the instructions in the owner's manual. To avail of warranty service, the Craftsman Snow Thrower must be returned to the nearest Sears Service Center/Department in the United States. It is important to keep in mind that this warranty applies only while the product is in use in the United States.
