13 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
536.885213
Background
The Craftsman Gas Snow Thrower, model number 536.885213, is a snow removal device powered by a 2-cycle engine. It is manufactured by Western Tool & Stamping for Sears under the Craftsman brand. The snow thrower is designed to handle snowy conditions, with a specific focus on functionality and control.
Among its features are an auger drive lever that starts and stops the auger, a chute deflector that can change the distance the snow is thrown, and a discharge chute that changes the direction the snow is thrown. It also includes an ignition switch key for starting the engine, a recoil starter handle for manual engine starting, and an electric starter button for starting the engine using a 120V electric starter. The device also has a choke control for starting a cold engine and a primer button for injecting fuel directly into the carburetor manifold for fast starts in cold weather. Other notable components include a spark plug access panel which aids in the removal of the spark plug, and a number of emission-related parts such as the carburetor assembly, air cleaner assembly, ignition system, catalytic muffler, and crankcase breather assembly.
Technical Specifications
- Engine Type: Craftsman 2-Cycle
- Engine Model: 143.025071
- Horse Power: 5
- Engine Displacement: 8.46 cu. in.
- Fuel Tank Capacity: 1.62 quart
- Fuel/Oil Mixture Ratio: 40:1
- Recommended Spark Plug: Champion RCJ8Y or equivalent (Gap 0.030)
Warranty
The warranty for this product is a limited two-year warranty. During this period, Craftsman will repair any defects in material or workmanship free of charge. However, if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. It also does not cover repairs necessary due to operator abuse or negligence. To claim the warranty, the owner should return the snow thrower to the nearest Craftsman service center or department in the United States. It is important to note that the warranty is only valid while the product is in use in the United States.
