12 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
536.88615, 536.886150
Background
The Craftsman Gas Snow Thrower 536.886150 is a dual-stage snow removal machine, manufactured by Western Tool & Stamping for Sears under the Craftsman brand. The snow thrower is powered by a 5.5 horsepower overhead valve (OHV) engine and features a 26-inch clearing width. The machine is equipped with a 120V electric start system for easier start-up in cold conditions.
The snow thrower has multiple features designed for efficient and versatile snow removal. The machine includes six forward speeds and two reverse speeds, allowing the user to adjust to various snow conditions and removal needs. It also features a chute deflector and crank assembly that adjust the direction and distance the snow is thrown. Other controls include an auger clutch, traction drive lever, and throttle control, which respectively control the operation of the auger and impeller, the machine's forward and reverse motion, and the engine speed. The ignition key and electric starter button provide options for starting the engine, while the choke control and primer button aid in starting a cold engine. The machine also includes a shear bolt, a safety feature designed to break if an object becomes lodged in the auger housing, protecting the machine from damage.
Technical Specifications
- Engine Power: 5.5 Horsepower OHV
- Thrower Type: 26 Inch dual stage
- Start Method: 120V electric start
- Forward Speeds: 6
- Reverse Speeds: 2
- Skid Shoes: Adjustable for changing auger housing ground clearance
- Shear Bolts: Included to protect auger housing if object is lodged
Warranty
The Craftsman Gas Snow Thrower 536.886150 comes with a limited two-year warranty. This warranty covers any defects in material or workmanship that may arise during normal use of the snow thrower. The warranty is valid for two years from the date of purchase, as long as the snow thrower is maintained, lubricated, and tuned up according to the operating and maintenance instructions in the owner's manual. It is important to note that if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. Additionally, it does not cover repairs necessary due to operator abuse or negligence. To claim the warranty, customers should return the Craftsman Snow Thrower to the nearest Sears Service Center/Department in the United States. It is important to remember that this warranty only applies while the product is in use in the United States. This warranty provides specific legal rights to the customers, and they may have additional rights that vary from state to state.
