11 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
536.88775
Background
The Craftsman Gas Snow Thrower 536.887750, produced by Western Tool & Stamping for Sears, is a product designed for the purpose of clearing snow. It operates with a 4-cycle engine, model number 12C414-0131-E1, which uses a carburetor system for fuel combustion. The snow thrower's engine comprises various parts such as a breather tube, crankcase cover, oil seal cap, intake gasket, throttle shaft, choke valve and shaft, main jet, carburetor overhaul kit, and many more.
The snow thrower is designed to be serviced and maintained by its user. It needs regular checks for loose or damaged parts, fasteners tightening, auger maintenance and controls functionality checks. If any parts are worn or damaged, they are designed to be replaced immediately. It is also designed with features like a stop switch, a mechanical governor spring/link, a control panel, a key switch, and a spark plug terminal. The gas-powered engine ensures that the snow thrower can function without reliance on electricity, making it a reliable tool in areas with frequent power outages during winter storms.
Technical Specifications
- Engine Model Number: 12C414-0131-E1
- Skid Height: Adjustable
- Cables: Pre-adjusted at factory, may need adjustment after handles are put in operating position
Warranty
The warranty is a limited two-year warranty offered by Craftsman. According to the document, Craftsman will repair any defect in material or workmanship free of charge for a period of two years from the date of purchase. However, it is important to note that if the snow thrower is used for commercial or rental purposes, the warranty only applies for 90 days from the date of purchase. The warranty does not cover items that become worn during normal use, such as spark plugs, drive belts, and shear pins. It also does not cover repairs necessary due to operator abuse or negligence, including bent crankshafts and failure to maintain the equipment as instructed in the owner's manual. To claim the warranty, customers are advised to return the Craftsman Snow Thrower to the nearest Craftsman Service Center/Department in the United States. The warranty service is only available while the product is in use in the United States.
