1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
580.328331
Background and Identification
The Craftsman Generator 580328331 Is a 2400 -watt portable A.C generator that was released in 2017. An AC generator is a machine that converts mechanical energy into electrical energy, generated as an alternating current sinusoidal output waveform. This generator is used to aid families, small businesses, etc. in the event of a power outage due to hurricanes, tornadoes, extreme heat, or cold.
The generator is black and red and sits on the ground. Unlike other models this model does not have wheels. The plugs are all located in the same place next to the power switch. The engine is a crank engine that is started by the recoil starter handle. The engine is manufactured by Kawasaki. The 2400 watt inverter generator is packed with convenient and easy-to-use features and is portable This equipment is a gasoline engine-driven and revolving field a-c generator set. The generator may be used to operate 120 volts.
In addition to its a-c power capability, the generator may be used to recharge a discharged 12 volts, automotive or utility type storage battery. The maximum rate of charge will gradually decrease as the connected battery approaches a 100 percent state of charge. There are no known FMEA or manufacturing recalls on the Craftsman 580.328331 Generator.
Technical Specifications
- Model Number: 580.328331
- Type of Equipment: Revolving Field a-c Generator
- Rated Maximum Continuous a-c Power Capacity: 2400 watts (2.40 kW)
- Rated Maximum Continuous Load Current: 20.0 a-c amperes
- Generator Circuit Breaker Rating: 20.0 a-c amperes
- Rated Voltage: 120 volts a-c
- Phase: Single Phase
- Rated a-c Frequency: 60 hertz at 3600 rpm
- Number of Revolving Field Poles: 2
- Driven Speed of Revolving Field: 3720 rpm at No-Load
- Type of Revolving Field Excitation: Direct Excited (Bridge Rectifier)
- Rated Maximum Battery Charge Output: 10 amperes at 12 volts d-c
- Battery Charge Circuit Breaker Rating:10 d-c amperes
Additional Information
List of parts and where to buy replacement
Youtube Playlists: Generator Troubleshooting
Youtube: Kawasaki FA210 5hp engine, Warm start and run after rebuild
